Results 1 to 10 of 14
Thread: gmc sierra 1500 with 2500 suspension and differentials !!!!
    Jul 2011
    Hello guys
    simply have a look
    obviously it's the latest model gm truck, but it has a full lift kit, suspension and differentials for 2500 (8 bolts wheels)
    which gives it an attractive look and reliable differentials.
    i've googled that but no result came up
    my question is : how to make like this ?
    Remove 1/2 ton parts, replace with 3/4 ton parts.
    Mar 2010
    Midland, TX
    SFA swap would net a better offroad suspension for the front but knocks on the fuel mileage. You can swap what ever axle you want to the rear whether it be from a volkswagon or a school bus. I've grenaded 3/4 ton parts in an IFS kit just as fast as I did 1/2 ton so I wouldn't look at this swap just for strength purposes on the front end. Truck does look good though.
    - 5.3 Stock Internals - Cal Speed Stainless LT's - 18" Magnaflow - K&N Drop In - Airaid Intake Tube - Nelson Tune -
    Shopping List
    - Cam - 3200 Circle D Stall - 10" King Coilover Shocks - 16" King Reservoir Shocks - FG front Fenders - 17" Methods -
    Jul 2011
    is it as simple as that !!!
    i don't think so
    because there are much difference between those suspension
    any more guys ?
    Mar 2010
    Midland, TX
    You could take a RCLB 3/4 ton and bob the frame and put a short bed on it.
    Shopping List
    Mar 2007
    As said....
    The rear is pretty easy to swap. I have a 14 bolt on the rear with a semi floating 14 bolt axle. Putting there a full floating 14 bolt will be the same thing, but will be heavy as hell.
    Now, the IFS swap is more than a challenge.
    The 9.2" front pinion and ring housing don't use the same location. Some have done this, but with serious Welder skills.
    The 9.2" will prove to be stronger than the 8.2" but you could buy stronger axles and hubs. and better material pinion and ring.
    Just my 2 cents.
    Mar 2007
    Quote Originally Posted by BigMac View Post
    +1
    Broken Bow, OK
    That would work, but a CCSB would be easier, take the extra out of the cab section on the frame.
    Jul 2011
    how many inch this lift kit is ?? what do you expect guys ??
    i really loved this car and i want to make one like this
    Sep 2010
    I vote its a 2500 with bobbed frame.
    It has torsion bars not the struts and the steering is totally different between the two.
    Plus the frame in that wheel well looks a little bigger than a half ton frame.
