Thread: Speedometer calibration problems
    Mar 2011
    Grand Rapids Mi
    I have a 5.3/4l60 swapped 1990 rcsb, when I did the swap I had 3.08 gears and just changed them out for 4.10's. When the peramiters for the speedo are changed the computer reads out the right speed but the speedo is still off. The speedo was right on with tje old gears but it won't read different on my dash but the laptop reads out the correct speed off the trucks computer? Any ideas could the speedo be on the wrong wire?????
    May 2007
    Oak Forest, Illinois
    Probably needs a D.R.A.C. calibration. I can't offer any info on it--I am not familiar with it. Do a search on this and other truck sites for D.R.A.C.
    Jeff
    Mar 2011
    Grand Rapids Mi
    It was the drac, thanks for the tip she's all dialed in now :-)
    glad you got it working, but why is your drac still in the loop? i wired my speedo ouput from pcm directly to the cluster. is this the wrong way to do it?
    Mar 2011
    Grand Rapids Mi
    mine was in the gauge cluster its self, so i could not figure out a way to bypass. some other trucks had a remote located drac mine did not it was a hassle but it felt great when it worked.
    1990 rcsb 5.3 4l60e swap 4.10 gears 3900lbs with a peg leg
    14.3 @ 95 1/4 mile
    9.1 @ 76 1/8 mile
    2.11 60' on street tires open diff
    gotcha, guess i caught a break and didnt even know it.
