			97 Burbon 4.8 swap help
					not sure if this is in the right place or not but. I've been doin alot of research here (and lt1tech) and there is alot of good info.  I had a 5.7 cpi and going to a 03 4.8. I have a good understanding of everything but there are a few things i can't figure out. I want to use the 97 fuse box which I've seen done but unsure which wires to pull from C2 and were to place them in the 97 fuse block. I'm going to delete the 97 pcm to clean it up. Can any one get me a good diagram on this or on my pcms the 03 is a 12570558 any help would be great. Also there is a black two wire connector going to the 97 pcm can't figure out what it is for.
					Here you go....http://www.youtube.com/watch?v=zaGQrdl_Tj8
 and here
 pdf file of above video
 http://www.hotrodlane.cc/PDFFILES/Lisa%20Tahoe.pdf
 I'm doing a swap with a 4.8l right now as we speak.  I've got coolant hoses, fuel setup, belt routing, a/c relocation, and intake to finish.  Oh, almost forgot the most important part...the harness.
 Jose
					Yeah i've watch the video and read the website several times. and i'm looking for pin outs.
					Got the wiring figured out for the most part but does anyone know what the damping lift/dive signal is on the 03 trucks. And the people going to DBW what are you doing about the hole in the firewall where the cable used to come through.
- You may not post replies
- You may not edit your posts
