Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: 12 sec. N/A 5.3 SCSB Z71
  1. #11
    <div class='quotetop'>QUOTE(Z71sierra7787 &#064; Feb 2 2006, 07&#58;14 PM) [snapback]43265[/snapback]</div>
    On the STS website i found this video of a Extended cab running a 12.9
    http://i.b5z.net/i/u/1473169/f/Video/Z71_Night_Run.wmv
    there are some other good videos of this truck making runs also
    yeah i think that one has the sts turbo on it though.
    Feb 2005
    Austin, Texas
    I ran a 15.1 with just exhaust intake tune and a 3K stall at 5400#s you can easily get into the low 14s with a cam lts headers and a few more little things you could get into the 13s IMO.
  3. #13
    Apr 2005
    Mine almost counts for 4WD, same frame I think, but only 2wd. Best I could do is 14.1, N/A on stock stall.
    Gone, but not forgotten!
  4. #14
    Jan 2005
    Conway, AR
    yes 13.27 on the stock stall. i&#39;ve done some pe tweaking lately and need to get it to the track. the time i have is on my Nelson tune, I am trying to learn this on my own now.
    Chris
  5. #15
    Feb 2005
    Austin, Texas
    James like I told you man there isnt an N/A 5.3 rcsb 4wd in the 12s and with what oyu have planned it will hit a 12 and I think it will in full street trim honestly. Especially since Ill be doing the work on it
  6. #16
    Jan 2006
    <div class='quotetop'>QUOTE(1slow01z71 &#064; Feb 3 2006, 10&#58;09 PM) [snapback]43470[/snapback]</div>
    Uh, yes there is&#33;&#33;&#33;&#33; One is a 6.0 and the other is a 5.3. I know the 6.0 doesn&#39;t count but some guy on LS1 has a SCSB 5.3 N/A Z71 in the 12&#39;s&#33;&#33;&#33; You better check your self before you wreck yourself&#33;&#33; I just wanted to see if anyone on here has been in the 12&#39;s as discribed in the above. As far as you doing the work, all I want you to do is fetch us beer when we need one and just for support.LOL&#33;&#33;
    James
    02 SCSB Z71:E-fans/nelson harness,ASP crank & alt,Volant ramair/k&n,UPD lid,Mac perf tube & elbow,Por & pol bbk 80mm TB/bypass,Meziere elec H2O pump,48# injectors,160 stat,LS6 intake,224/228,.581/.588,110šsep.,Dart 205&#39;s,Supermaxx header system,Corsa Sport,MSD 8.5 & coils, NGK #6(indexed), Built 60E,Fuddle 3400/cooler,custom alum ds/billet trans & pinion yolks,Weld chyenne 6D&#39;s, BFG kdw&#39;s, Nelson SD tune.
  7. #17
    Jan 2005
    Conway, AR
    I think he meant ecsb, ex cab adds a few pounds&#33;
    Chris
