Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: AWD Transfer case
  1. #11
    Feb 2008
    Texarkana tx
    Bump bump
    2002 RCSB Z71, 409 with stock heads, custom spec cam, vic jr intake, t-76 Q-trim front mount, Tim Frost 4l80e trans, eaton posi, and the list goes on.
  2. #12
    The Garage
    bump again for a great seller
  3. #13
    Ponca City
    Quote Originally Posted by bluchevypick View Post
    No. My truck leaves hard on 7psi launch and the front end raises and it dont light them up but will spin a little. thats why i said if your making 500 or less. My truck is making well over that. Im going to 80e also and they dont make a 32 spline input for this case or i would keep it.
    Theres a guy that sells the adapter for the 80e to the awd t-case over on SSS.com. less than $400 i believe
    Slowest in Oklahoma...
  4. #14
    Feb 2008
    Texarkana tx
    Way more than i want to spend when i already have a case that will work.
  5. #15
    Feb 2008
    Texarkana tx
    bump bump
  6. #16
    Broken Bow, OK
    I guess I don't see the point in using the BW case without the stock ABS system doing traction control duty. Seems like now you are able to lose traction at 4 wheels instead of just 2.
  7. #17
    Feb 2008
    Texarkana tx
    Well like stated above.....I have been running a 6.0 boosting 7psi and not having a problem with it. matter of fact here is a video with me launching under boost. You can hear the front tires barely spin.
    http://www.youtube.com/watch?v=G9TfPY1qhF0
  8. #18
    Feb 2008
    Texarkana tx
    Sold!!!
