Results 1 to 1 of 1
Thread: NNBS TPMS Relearn
    Orono, ME
    NNBS TPMS Relearn
    I saw Greg posted in a for-sale thread about doing the relearn for TPMS sensors for NNBS trucks. Here's the procedure, hope it helps someone:
    -Take valve stem caps off (procedure goes quick, better to have them off prior to starting)
    -Turn key to ON position but don't start
    -Press the lock and unlock button on your key fob until your horn honks ONCE (those of you without remotes can access this by using the DIC info button)
    -Go to drivers side front tire and let out air for 5-15 secs until your horn honks ONCE
    -Go to passenger side front tire and let out air for 5-15 secs until your horn honks ONCE
    -Go to passenger side rear tire and let out air for 5-15 secs until your horn honks ONCE
    -Go to your driver side rear tire and let out air for 5-15 secs until your horn honks TWICE
    -After the horn honks twice, the relearn is done.
    -Check tire pressures and reset to desired pressure
    -Reinstall valve stem caps
    2012 Honda Civic Si - DD
