Almost every other time I start my truck, the rpm goes up to around 2200rpms then goes back down normal. It does not matter if truck is cold or hot. Truck is an 05 5.3 bolt ons, cam, stall, tbss intake. Any idea what could cause this?
03' Silverado RCSB H/C 5.3, 4L80,76mm KBracing Kit
13' Sierra Denali 2500HD CCSB 4x4
Idk man thats strange have you took a scan of your tune?
Mine does the same thing but only on cold start ups to around 1800 RPM. Goes down if i tap the gas pedal. Once it is warm it is fine.
May be a bad IAC or 02's aren't getting a good reading maybe and calling for fuel. IDK, helps my truck warm up faster.![]()
2013 CC 5.3
81 C10 LS1 project
Haven't had it scanned, asked my tuner about the problem, he did not know either but he told me another truck does the same thing. The owner of that truck has tried everything and still nothing.
I replaced one 02 already cuz it was complety dead. I'll check into the IAC.
is it just high reving to warm the motor up? mine revs high when it first starts but then drops with in seconds back down to 1200 when its super cold and about 650-700 warm
2006 Chevy ECSB 5.3 - New L33 Motor,CAI, Descreened MAF, Nelson 93 tune, Transgo Shift Kit, servos, 3in exhaust, Borla, pacetter LT's, and ORY, Aeroforce Furture: stall, cam, 4.10's
Its just when I turn it on initally, the rpms jump up then within seconds it goes down back to normal.
if it's not a vac leak, i know what it is![]()
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
Spread the word.....
I have change IAC, TPS, Accel Cable, Reworked the TB, and nothing !!!!!
well i think this is it, if the truck is 100% mechanically sound, do this to the calibration.
under spark tables, set Startup Flare to -64, see what that does.
Nelson Performance
NP on Facebook
Youtube Channel
