Results 1 to 10 of 22
Thread: Nitrous backfire Q
    Nitrous backfire Q
    Some of you guys are running n20 throttle plate wet kits from what I’ve seen in the “my garage” section, how many of you have had a n20 wet back fire? I’ve seen pics of ls1 intakes after a back fire and there blown apart, is the damage as bad with a truck intake manifold?
    Oct 2009
    Reidsville, Georgia
    I had a back fire once when i was still using my shark nozzle, but it was my fault. backfired on #7 and blew the back of the intake apart and broke the oil sendin unit. if the tune is on usually, no worries
    2000 2-toned silverado, Totalled. Gone But not Forgotten.
    Now: 2002 black rcsb chevy. 5.3, P&P 862's, Comp 224/230 .58*/.59* 114 LSA, Racetronics 44lbers, ARP 2000's, Ebay long tubes, 4L80E, 3800 yank pro, transgo HD-2, 4.10's, True-Trac, Walbro 255, Nitrous Outlet plate setup for 200, 80mm BBK, 3" Magnaflow, and Raggedy traction bars! Waiting to be istalled, F.A.S.T LSx intake..........
    Best: 7.40@90 1/8th
    Tuned by: DIXIE PERFORMANCE
    thanks for the reply man. why was it you fault?
    Quote Originally Posted by 00buckshot View Post
    and ONLY SPRAY at WOT above 3k rpms
    Birmingham, AL
    the tune causes backfires?
    01 Silverado
    Maybe that's what caused fight fighter Jeffs truck to burnt to the ground..
    and that is the epitome of irony.
    Oct 2009
    Reidsville, Georgia
    No, smart ass, I was just tryin to reassure the guy, i said the backfire was my fault, so dont get sarcastic on me
    Best: 7.40@90 1/8th
    Birmingham, AL
    oo, sorry! ill take the internets more seriously next time!
    01 Silverado
    Ive only had 1, and it took like 3 years and it was my fault, first of all it was minor all it did was blow my cold air intake off so no biggie, how it happened is after my pass while letting off the gas I didnt let go of the button
    from what ive read a back fire is caused by:
    1: lean running condition (ie bad tune/ distance between the fuel node and fogger)
    2: poor choice in temp range spark plugs
    3: what g just added
    4: lunching under n20
    5: applying under 3000 rpm or spraying into rev limiter
    have i missed any?
