not sure if you have found the problem yet but One truck i had worked on before had no action from one coil. these coils use battery positve, pcm control and also the low reference signal. it can full you checking the low reference because it wont light an ordinary test light if checking. you need a meter to see if its getting voltage there. im guessing you already knew that, just thought id throw that out there.
