Results 1 to 5 of 5
Thread: Noisy Valvetrain?
    Oct 2009
    Seattle, WA
    Noisy Valvetrain?
    Since I put the 383 in my truck the valvetrain has been really noisy. Is there a way to quiet it down through the use of different rockers, pushrods, etc?
    I currently run a TR220-114 with stock rockers.
    I plan on tearing my motor down to replace the heads and cam to set up my motor a little better for a turbo so I will have it apart anyways.
    .Ty.
    2003 GMC K1500 ECSB running an Iron 383 Stroker ......
    Pittsburgh, PA
    do you have correct lenght push rods? please dont say you used 7.4s without a proper measurement of what you actually needed. that right htere could be yoru sole problem with noise.
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Oct 2009
    Seattle, WA
    hahaha. yeah thats what i used. guess I will go and get a correct measurement when I swap the heads.
    Oct 2009
    Seattle, WA
    Can I change the pushrods out with the cam and lifters in the engine? If I can, I was thinking about getting a real world measurement of the pushrod and maybe swapping them if thats my problem. It might be a while before I swap my heads.
    Sep 2010
    middle tennessee
    Sure you can, pull the coils and valve covers, remove the rocker arms and go to town! You can buy comp push rod lenght checkers from summit.
    99 silverado 2500 4x4 ec lb, lq4 with 243 heads, pace setter long tubes, true duals with x pipe and bullet mufflers, comp 222 224 112 cam, 8.1 truck injectors, 4l80e with 2800 stall, 373 gears, 285 75 16 tires, efi live tune in progress, 350rwhp 360tq, 11.8 average mpg mixed driving
