Thread: Speedometer problem
    Jul 2005
    Galesburg Il
    Speedometer problem
    I have a new Coan 4l80E trans in place of the 4l60E that I tore up. Now that it's installed the speedometer runs at what appears to be 1/2 speed.
    How can I correct this?
    2002 white Silverado ext cab. Taillights filled, roll pan w/93 Cad lights horizontally placed, tailgate handle inside, Gaylord tonneau, bed slide & bed rug, all trim removed, Escalade door handles, 18" Enkei & Falcons, Speed grill. Grill shell, bumper pad, & valance painted white. Mirrors painted white. Many interior pcs painted black (over beige), black leather seat inserts and sun visors. 2" dropped DJM lower control arm, shackles/hangers for 4" rear drop. Engine: 5.3 , Radix w 2.8" pulley, 90 mm throttle body, Dart 225 heads, Comp Cam 581-588 224-230 on 114. ARP head bolts. KTech rod bolts. Alky Control methanol injection, Pacesetter lt's into elec cutouts then 4" polished Magnaflow SS mufflers then 4" ovalized SS pipes exiting in front of rear wheels both sides, gas tank removed and 24 gal. fuel cell where spare tire was w/Aeromotive pump, pre and post filters and pump controller & -10 SS fuel line. 160 thermostat MSD wires & Perma Cool fan, 34" radiator, Meziere elec water pump. Valve covers, alternator & brackets powdercoated white. Built 4l60e, 4.56 with Detroit Locker Trutrack. 2 Interceptor logging guages, FAST dual 02 sensor wb gauge, Cyberdyne vac/boost gauge. Truck is actually the property of a little Benji type dog. Pics of him and the truck too www.swardphotos.shutterfly.com
    Houston
    did you wire and plug in the second vss and swap the harnnes pin for mail trans conector?
    Jul 2005
    Galesburg Il
    I'm not electronically literate and I have NO idea what you just asked. I had someone else do the work.
