Results 1 to 10 of 20
Thread: Fluid or Trans failure
    after driving on the imterstate for 40 miles running 85+ I notice the engine revving high, should be at 2500 but was at 3k, and give it more gas and it tachs higher without an increase in speed, i was already AT MY EXIT so i get off and come to a stop sign, take off and it goes through first fine, then shifts to second and revs freely, up to around 5k, i let off and it shifts into third and acts fine, i pull in where we're eating and check fluid, full but dark burnagady with no smell. after an hour dinner I drive it 50 miles home with zero problems, babying it of course, later when it was cold again i went for a test drive, stomped it and no slppage?
    ideas?
    Psalms 144:1
    Si vis pacem, para bellum
    Oct 2009
    Katy ,Texas
    Common failures on 4L60E, symptom < cause > any possible repair:
    1. Slow, slipping or no reverse: “lo-reverse” clutches are worn out, fluid leak in the reverse apply circuit, or broken sunshell. It is possible to remedy a fluid problem by removing the checkball from its cage in the case in the rear of the trans may help (must remove valvebody), or adding a high-viscosity additive such as Lucas Transmission additive or other seal restorer product. May also have worn boost valve (can replace in the pan).
    2. 1-2 shift does not happen at WOT until you let off the gas: Best case: try replacing the TPS. Middle case: leak in the 2nd gear apply circuit (servo assembly or 1-2 accumulator). Doublecheck by using the pressure gauge and watch for a big drop when the PCM commands 2nd gear. Worst case: poor line pressure rise (see below).
    3. 1-2 Shift shudder at WOT; delayed or abnormal 1-2 shift; There's a problem ONLY on the 1-2 shift: 1-2 accumulator piston cracked or stuck cocked in the bore. Check the yellow spring inside the accum housing for breakage. Also, if the accumulator housing walls are scored, the housing must be replaced. Easy fix in the pan.
    4. 1-2 shift is delayed and harsh, may not shift into OD: Check TPS for smooth and linear electrical response over the entire range of motion. If not, replace.
    5. Trans does not upshift out of first, speedometer reads zero at all times: VSS failure. Easy fix on rear of transmission, but xmember must come out to access VSS.
    6. No 3rd or 4th gear: “3-4” clutches are worn out. R&R. The car is safe to drive (in 2) until you can get it fixed.
    7. Sudden grinding noise with no prior warning primarily in 2nd gear, behavior in reverse may be abnormal; sunshell is fractured. R&R. Try not to run or drive the car or further damage could result.
    8. 1st and 3rd only, no 2,4 or R; sunshell is fractured or splines are sheared off. R&R. Try not to run or drive the car or further damage could result.
    9. No 2nd or 4th gear. 2-4 band is slipping. Servo seals may be damaged (can be fixed without removing trans. Otherwise, 2-4 band is worn out. R&R.
    10. Trans shifts into gear harshly, car feels sluggish off the line, No 1st, 4th or TCC lockup available, Manual 2nd, 3rd and Reverse are only available gears, CEL is on: Transmision is either in limp-home mode or has lost electrical power. If there are lots of error codes in the PCM, check the underhood fuse that powers the transmission, and if it pops again, look for a short in that circuit like an O2 sensor harness touching exhaust. Otherwise, check PCM codes for a particular fault in the transmission causing the PCM to put it in limp-home mode.
    11. No 1st or 4th available; trans shifts 2nd to 3rd by itself in D or OD and locks the converter : ShiftA solenoid failed. Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
    12. Car goes into gear but feels very sluggish like the brakes are dragging, but it will roll easily (starts out in 4th gear), you manually shift to 2 to get it moving, once it's moving you put it back in OD and the car shifts 3rd to 4th on its own and locks the converter at the appropriate time: ShiftB solenoid failed: Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
    13. No TCC lockup: Brake pedal switches improperly adjusted (always on), TCC solenoid failed (easy fix in the pan), TCC clutch worn out (must remove trans and replace TC).
    14. TCC always locked: TCC apply solenoid circuit shorted to ground, TCC solenoid blockage (easy fix in pan), or TC broken (must remove trans and replace TC).
    15. Horrible noise in 4th and feels like the brakes are on: overrun clutches are applying due to a cracked or leaking forward piston. Overrun clutches will be worn out after 30 seconds of this behavior. Car can be safely driven in D. R&R.
    16. Soft shifting, gradual performance degradation: Poor line pressure rise due to leaking boost valve, clogged EPC filter screen, failing EPC solenoid, or worst case: leaky seals throughout. Transgo HD2-C kit fixes first two without removing trans. Seal restorer may fix last problem, but probably R&R. Also try a transmission flush with BG brand products (Firestone stocks it).
    17. No forward movement in OD or D, but L2, L1 and R work: Forward sprag is broken. R&R. Try not to run or drive the car or further damage could result.
    18. Extremely harsh shifts from P or N, normal shifts at WOT: EPC (Electronic Pressure Control) solenoid failed. Easy fix in pan. Fix as soon as possible or hard parts will eventually break.
    19. Loud bang, grinding sound, loss of all gears, and a binding driveshaft: snapped output shaft. Try to wiggle driveshaft - if more than 0.020" play, that's the sign. R&R.
    20. Trans seems noisy when moving in 1st and Reverse, noise goes away instantly if you shift to N or the trans goes into 3rd gear: Reaction planetary is worn out due to high miles or insufficient lubrication. Not a critical failure, but not a good sign either. R&R sooner rather than later.
    21. No movement in any gear: pump failure, or total loss of fluid. R&R, or refill pan and find the leak. If out of fluid, avoid running the engine until the trans is refilled to avoid pump damage. To check for pump failure, check fluid level with the engine off, then start the engine and recheck fluid level. If level does not go down when engine is running, the pump is broken.
    22. Transmission does not shift automatically, only manually. Swap in a known-good PCM, check wiring, check other sensors such as VSS and TPS.
    23. 3rd gear starts, can manually shift through all gears. When car has been turned off for a bit, then back on it will run normally.: VSS dropoff w/ Hi-stall converter. The rpms are too high, but VSS is showing no movement. Happens after a tire burning take-off. Doesn't store a code, will not throw a CEL (I've heard that it will store a code if it happens 3 or more times). Cure: Reprogram PCM for VSS dropoff -- PCMforLess knows about it.
    24. Fluid leak out of the front of trans where the converter connects; partial or full loss of movement: Front pump bushing walked out. R&R. May have to replace converter also if hub is scored. Note that a leaking front seal usually means the bushing is walking out (i.e. call your local trans shop and schedule an appt.).
    25. Torque converter shudder in 4th while lockup is engaged; problem goes away when the brake pedal is pressed slightly to unlock converter. Have a shop verify line pressure, and provided no valves in the TCC hydraulic circuit are worn, replace the torque converter. Also, Lubegard Shudder Fix will at least fix this for awhile. Or try a transmission flush by a shop that uses BG brand products.
    26. Shift suddenly become very hard. When going from park to either reverse or drive it slams into gear. 1-2 and 2-3 shifts are also harsh. All gears seems to work. Problem may be intermittent: Check TPS for smooth electrical response. If the response is jumpy or erratic at all, replace TPS.
    27. All fluid pumped out through the vent tube: Plugged cooler line. Flush the transmission cooler and cooler lines. Also could be overfiled transmission.
    28. Car acts like it's in OD in neutral, car is locked stationary in R, engine feels loaded in P, all four forward positions work fine: R&R: Internal crossleak feeding the forward clutches all the time. Most likely a cracked input housing, or cracked forward piston means forward clutches are fused together. Car can safely be driven gently in forward gears until the repair.
    29. Needle bearings in the pan, first gear and/or reverse may be noisy: Either a torrington bearing or a planetary bearing is on its way out. Trans will eventually die a loud, catastrophic death. Cheaper to rebuild now (saves further damage to hard parts), but requires R&R. It is drivable until it breaks.
    30. 1-2 or 2-3 shift is slow/soft above part throttle: Trans is on its way out. R&R.
    06 silverado crew cab 4.8L
    STS Kit W/turbonetics BB 60-1 .81AR T4 and intercooler 10psi
    Nelson custom tune
    built 4L60E-hopefully it lasts
    2500 stall-Hughes converters
    42LB injectors
    3.5 Magnaflow exhuast
    6inch lift on 35x12.50s
    #9 sounds like it.... band slowly starting to go? whats the chances a seal started leaking without it being worked on?
    Psalms 144:1
    Oct 2009
    Katy ,Texas
    its the first place i would start , the servo is easy to remove , otherwise it could be the 2-4 band wich would require to pull the trans.
    Nelson custom tune
    42LB injectors
    are you talking about the 1-2 servo? i've had a vette servo sitting here waiting for along time
    Psalms 144:1
    Jun 2010
    West Texas
    The servo is what makes the band grab. Sometimes adding a stronger servo helps slippage but it sounds like in your case rebuilt is needed.
    RUN WAT U BRUNG!!!!
    after i let it cool down later the trans acted fine????
    the 1-2 servo is the one refered to?
    Psalms 144:1
    pulled the pan... magnet is clean... fluid doesnt seem to bad.
    Psalms 144:1
    Oct 2009
    Katy ,Texas
    yes the servo on the right side of the transmission is the servo for 2nd and 4th. you can install the vette servo and see what it does, might tighten things up a bit, like i said servo is easy ,just MAKE SURE you completly install the snap ring completly for the servo cover when you remove it., sometimes it looks seated but its not .
    might be time for a rebuild or at least a 2-4 band
    Nelson custom tune
    42LB injectors
    do your have to drop the y-pipe to take the servo out?
    Psalms 144:1
