Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 38 of 38
Thread: 4.8 to ly6 swap finally done!!
  1. #31
    so how was this swap ? easy... hard... ??
    2009 CHEVROLET 1500 with a MONSTER 4.8 between the frame rails!!
    Tuned by LSX Powersports ~ 4.10 ~ JBA Shorties ~ 4" Inlet/Outlet Spintech ~ Airaid Coldair
    CST 3.5" Spindles ~ Camburg Upper Control Arms ~ 2.5" CCM ~ FFR Tie Rods
    Full Throttle Suspension 3" Lift Blocks ~ Soft 8s wrapped in LT285/70/17 Silent Armors
  2. #32
    it was easy ,swapped right in,minor issues here and there.
  3. #33
    Quote Originally Posted by STUNNA View Post
    what kind of issues did you have? Did you do the swap or someone else? Did you keep the VVT? I am planning to do a LY6 swap on my truck pretty soon too. Any info and tips would be great. Thanks
  4. #34
    Quote Originally Posted by mrgrinch77301 View Post
    i did the swap myself,it was easy swap.minor issue well wasnt big of a deal was i had to delete the vvt cam ,retain factory 4.8 cam/sprocket and use the 4.8 timing cover...when i pulled the 6.0 cam out it brought out a cam bearing...so i got em all replaced.its real easy bro.i should be getting my custom grind cam in soon cant wait
  5. #35
    to keep the vvt i would need the ecm from the truck in came from right? I'm planning on getting a Mast cam and then a wheatley tune
  6. #36
    no u can just tell wheatley to tune it for that
  7. #37
    thanks for the info. I want everything to go smooth since the truck is my DD and I use it for school
  8. #38
    what tranny are you running on it?
