That looks like a decent cam. Expect to spin it fairly high and run dual valve springs.
Not sure what it will run. I'll find out this friday
2007 RCSB|DTR81 built LSx 3xx|PRC|NX|BOGART|MSD|QUICKFUEL 950 E85|4L80|FTI Converters|Smith RaceCraft|Racepak
midweststreetcars.com
What are you expecting it to run? Do I need to change anything else but the dual valve springs?
Man, I don't really know. Hopefully somewhere in atleast the 12's.
chome moly push rods, might check the length on them. most off the shelf cams use 7.400 assuming the heads are stock. Thats pretty much it
Are you not worried about the lift over .600 on stock heads?
Not a bit
I'm going with the Texas Speed Torquer v.2 Camshaft. Think that is a good choice?
That cam is too big imo. Would need more stall speed and gear to take full advantage of it. I wouldn't go any bigger than a 228...
I figured a 3600 stall and 4.11 would work good?
It all depends on what you want from your truck. Everyone recommends what they read on the internet, and your setup is something someone definitely WOULD NOT recommend. With that cam and stock heads and a 3600 verter with 4.11's, NO it WILL NOT be optimal...BUT, the truck will still run good. To make the most of that cam, you'd need a good intake; vic jr or some sort of FAST intake, 4000+ converter, 4.56 or deeper gears and some good tuning.
These people make it seem like your truck won't even run if you put that cam in your truck...Not true at all. With some slicks on a 100shot you're prolly still going to run some mid to low 12's. How often do you go to the track? Do you do any other racing with it? Roll racing? That cam won't be easy to tune, depends on how much time you want to put into it.
Like I said, what do you want to do with your truck? If you're wantin to set the world on fire with it, you better sit down and figure out a game plan. If you're expecting just that big cam to get the job done, you're gonna be very disappointed. If you just want it to make some good numbers on the dyno, run decent at the track, be fast from a roll and have a mean enough sound to make old women cry, then yeah, that will work for you.
It's been provin time and time again, you can't really go wrong with the tr220 or tr224. I don't care how many of the custom cam grinders say those lobes are old and wore out...The fastest stock longblock 5.3 still belongs to blue cajun who still has the old wore out tr220.
The plan for the truck is that I want it to run constant mid 12s and I would like it to be in the 12s on motor. I know a big cam wont put me there, that is just one that was suggested to me. The truck only gets taken to the track at the most twice a month and that's it. I always go from a roll, due to traction also. It pulls good now but I know that is just a small cam so I figured it might wake it up a lot to change it. I'm open to any suggestions that anyone has. I just hope all my questions may help someone else also.
Also do they make a nitrous perimeter plate for these trucks?
