Results 1 to 9 of 9
Thread: Power steering fluid
    Union, MO
    So I've notice some fluid on the underside of the corregated section of my steering rack. I don't see any leaks anywhere but fluid keeps showing up. Any ideas?
    Plainfield, IL
    mine does the same thing. I don't lose any fluid, not sure if it's from pump overflowing when hot/turning wheel to hard, or the rack seals leaking slightly. As long as you aren't constantly adding fluid, I wouldn't really sweat it.
    Union, MO
    I've never had to add fluid to it. It doesn't drip, it's just wet.
    Mar 2010
    Paris, TX
    It is the seal leaking on that side of the rack. I bet the rack boot has quiet a bit in it if you were to take it loose. If it is not dripping and is just wet; I would just spray it off with some brake cleaner at every oil change. However, if it gets worse I would swap out the rack.
    99' Silverado RCSB Z71: 5.7L Iron LS1, 11.2:1, Custom EPS Cam, Ported 862's,Ported TB, E-Bay Cold Air, E-Bay Long Tubes, Dynomax X-Pipe Exhaust, Electric Fans, Innovative LC-1, Self Built 4L60E, Circle D Pro Single Disc, 4:10 ValueTrac
    http://www.ls1truck.com/forums/image.php?type=sigpic&userid=7887&dateline=1270435  715
    Union, MO
    Errrrr. I was hoping somebody wouldn't say that. LOL! Is it hard to do?
    Mar 2010
    Paris, TX
    Not to bad to swap takes about an hour or two depending on your friends. You have to get an alignment afterwords to get the toe set right.
    Union, MO
    Any idea how hard it will be to get the tie rods ends out of the spindles?
    Union, MO
    So is putting a new rack in a 2 person job?
    Jun 2010
    baxley,ga
    no you can do it by urself.just unbolt ur power steering lines from rack,i shaft,un bolt ur tie rod ends from spindles and knock them loose with tie rod end seperator.unbolt the rack and slide it out and put new one in,in the reverse order
    04 rcsb forged 347
