Results 1 to 10 of 13
Thread: transfer case selector acting up
    verona, virgina
    awhile back i had a issue with my t/c selector going haywire and randomly being in diffrent gears some sugested to clean the grounds and well its now doing it again but flashing service 4x4 and the other day all the lights for the diffrent 4x4 gear sellections were out and the dic flashed service 4x4 but after it sat off for 30mins or so and i started it back up it was fine and back in 2wd.
    03 yukon xl:intake, longtubes ory,performabuilt lvl2,circle D 278,tune, tint, lt1 fans
    92 z28: lb9 air foil vette servo magnaflow catback adjustable pan hard rod Lcas lcarbs
    86 trans am: lm7 hot cam th350 3500 stall
    Jul 2010
    Sharpsburg, GA
    I had the same kinda problem when I bought my truck used in 04 turned out to be the switch on the dash itself. Take one out of a friends and give it a try before you buy.
    Quote Originally Posted by screamin86 View Post
    Mar 2010
    Paris, TX
    Mine was doing this also. A friend of mine who is a GM tech said to replace the switch or resolder all the connections inside. The cheap scape and rigger in me decided to solder it. Has not acted up for two years now.
    99' Silverado RCSB Z71: 5.7L Iron LS1, 11.2:1, Custom EPS Cam, Ported 862's,Ported TB, E-Bay Cold Air, E-Bay Long Tubes, Dynomax X-Pipe Exhaust, Electric Fans, Innovative LC-1, Self Built 4L60E, Circle D Pro Single Disc, 4:10 ValueTrac
    http://www.ls1truck.com/forums/image.php?type=sigpic&userid=7887&dateline=1270435  715
    verona, virgina
    well i know when i had the problem before it would actualy be in like lets say 4lo or auto 4x4 usualy when it would show 4lo it didnt act 100% like it does when i put it in the gear but i could tell something wasnt right. ill try to pull it apart maybe this weekend and see whats going on.
    Jul 2010
    Wish I had that kind of experience. You got the 6th sense working.
    Mar 2010
    Paris, TX
    Did you fix this yet or has it stopped acting up?
    Aug 2010
    El Paso, TX
    The 4wd switch itself goes bad eventually. That, or the transfer case motor has a connection go bad. Both are cheap fixes
    2006 Silverado 1500 Z71 in Blue Metallic - L33 5.3L, 3" body lift, 2.5" level, 35x12.50x17 BFG KM2's, 17x9" DC-2's, K&N, Stock 4.10's, G80
    1984 C10 in Sky Blue Flake - 383 stroker, Holley 760 Avenger, K&N, cam, heads, long tube headers to 2.5" true duals, 4.10's, Turbo 400 w/ shift kit, frame-off resto
    My Garage - http://www.ls1truck.com/forums/my-ga...66-my-gms.html
    Dec 2008
    South Carolina
    mine did the same thing and i replaced the switch in the dash for $125 and haven't had a problem since
    2008 GMC Sierra SLE....370ci LY6 with some goodies SOLD
    verona, virgina
    if i can find a day where i have time to look at it i will been working alot lately and had to pull the heads off my k10 the other day so im in the process of putting that back together.
    Racoon Twp., PA
    More than likely it's the motor. BUT i have a extra push button switch out of my 99 if you would like me to send it your way just to help eliminate one thing.
    2013 CC 5.3
    81 C10 LS1 project
