Thread: Help with PCM Codes
    Feb 2008
    Kanada
    Help with PCM Codes
    After a year now iam getting SES codes po 420/430. I have long tube heaers no cats, and have turned off all o2 sensor with the Diablo. Could a small exhaust leak cause this problem. The PCM was tuned when it had an exhaust leak last year.(not knowing there was a leak). I fixed the exhaust leak this weekend, but it still throws these codes, after a test drive a random missfire code came up as well. Cleared it, and it never came back. But still po420/430. Has anybody had this problem before?
    May 2007
    Oak Forest, Illinois
    P0420 is Bank 1 and P0430 is Bank 2 Catalyst Efficiency Below Threshold. Since you have no Cats on the truck---You need to have those 2 codes deleted in the tune.
    Jeff
    Feb 2008
    Kanada
    po420/430
    I have turned these off
    May 2007
    They can't be off if they are coming up as codes.
    Jeff
