Results 1 to 8 of 8
Thread: Turn Signal Switch
    Jun 2009
    Santa Paula
    Turn Signal Switch
    HOW DO YOU TAKE OFF THE COVER AROUND THE STEERING WHEEL GOING TO REPLACE THE TURN SIGNAL SWITCH
    ff_jeff Guest
    If I remember my 04, it was clipped together. I think you need to find the seem. It might have a few screws. But its been a while back when I had that.
    Most of the dash is held by just a few screws. But you have to take it apart in order. Because some pieces overlap others.
    Jun 2009
    Santa Paula
    IT LOOKS LIKE THERE IS TWO SCREWS BUT THERE IS ALSO ONE HOLE LIKE IT DOES SOMETHING ELSE???
    ff_jeff Guest
    best thing to do is pop off the lower dash, and upper dash/ bezel that covers the stereo and ac stuff, all one piece that pops off. Then get a better look. Good practice too. that way next time you have to pull it off, its easier.
    Jun 2009
    Santa Paula
    THANKS FOR THE HELP...
    ff_jeff Guest
    no problem
    Cedar Park, TX
    for mine i had to pull of the upper dash bezel, then the cover around the turnsignal, wiper, etc just pulls right off. it's held in by flimsy plastic clips.
    R.I.P Blue '02
    '08 - 5.3
    Vette Servo, Flowmaster 40
    Nov 2009
    chicago, il
    Like a bandaid, one quick strong pull
