Results 1 to 10 of 15
Thread: 6.0L with 5.3's heads??
    Feb 2008
    Arizona
    hey guys, what happens if I do a 5.3 to 6.0 and install the 862's to the 6.0? the thing is I had them ported, polished and the 3 angle valve job on them and kind of would like to stay with them if they will do me any good.. or should I use the ones the 6.0 have?? cause i dont think I can afford the heads job again right now..
    thanks guys!
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
    Augusta, Ks
    Will work fine. Will bump up compression
    2004 Buell XB12s
    Feb 2008
    Arizona
    so it would be better than 6.0's heads?
    Oct 2008
    Houston
    You will gain a lot of low end torque and lose a lot of top end horse power.
    Alot of people down here swap 5.3 heads to bump up the compression with good results.
    03' Silverado RCSB H/C 5.3, 4L80,76mm KBracing Kit
    13' Sierra Denali 2500HD CCSB 4x4
    will work fine
    had a friend with and lq9 6.0 and had an ms3 cam and 862 heads ported, milled, and valve job and went 12.3 with traction issues. so i think it will work good.
    Feb 2008
    Arizona
    Quote Originally Posted by rdsmoke View Post
    WOW! That will work!! It would work better in a Lq9 vs Lq4 right?? I'm talking N/A..
    Quote Originally Posted by White Devil View Post
    heres a comparison dyno the red ( 402 rwhp) is when i had ported 706 5.3 heads..
    the blue line is from a head and cam swap
    Simple: 408 on steroids!
    single digits coming soon!
    It will always "work better" when you run them on an LQ9.
    BUT...since the cc is a lot smaller on the 706/862 heads (about 10 cc), you deck them a little...and they are going up against an LQ9's flat top pistons--there might be a concern of PTV. But since this combo has been fashioned before and there have been no major problems, I am sure you'd be fine.
