Page 3 of 3 FirstFirst 1 2 3
Results 21 to 22 of 22
Thread: Brand New 4L80e 4wd
  1. #21
    Quote Originally Posted by kbracing96 View Post
    A 4x4 60 to 80 swap is more involved as the tranny/transercase is moved back about 1 11/16. A stock front drive shaft from a 2500/3500 truck (you must tell them its for a 5speed trans to get the right one from a junk yard) will fit and you have to shorten the rear shaft 1 11/16, as well as cutting the cross-member and moving it back. Also, as stated the input gear on the transfer case must be changes out the the 4l80 gear on the autotrack and a special made one for the AWD tranfercases. It also uses a different adapter between the tranny and transercase then the 60 does. It is much more involved then 2wd swaps.
    PS, Would be nice to have this tranny for a spare, You should hold it for me until the LS1truck track day in case history repeats its self,
    Man that is some good good info. Let me make sure I am seeing this right.
    AWD truck SS or RCSB should not matter either one will use a 4l80 and a 5 speed 2500hd shaft? I am so excited. No 300 dollar shaft for me. Woooo Hooooooooooo. Thanks for posting that.
  2. #22
    Apr 2005
    The Woodlands, TX
    Yep, it should. I just had to get one ($50) from a junkyard (while on a PT.net GTG trip, lol) to replace my expensive one I got when i first did my swap that was custom made with a stupid CV joint that failed, that it didn't NEED!
    The first junk yard one I got I told then I needed one for a 3/4 ton 4 speed tranny and it was too short. They said it should fit 1/2, 3/4, 1 ton. Had him look up the shaft for a 5 speed trans and it was for 3/4 and 1 ton only. Got that shaft and it was perfect length, just like the custom made one.
    So now I have both the custom front and rear shaft I had made for my truck are sitting in my shop with about $600 into them and they are useless (rear shaft has a vibration that 2 different shops can't get out of it) and my shortened stock rear drive shaft (didn't know he could shorten and balance a 5" aluminum shaft) and a $50 stock front shaft are in the truck, lol.
    01 ECSB 1/2 ton 4x4 6L GMC
    11.03@127
    KB Racing Borg Warner S475 turbocharged
    http://i3.photobucket.com/albums/y57/Kbracing96/kbracing96copy-1.jpg
