These are similar to 4 link systems, except!. . . they fasten to the tail end of the frame at the rear of the bed. I came up with this idea sitting at my computer pouring over countless how-to's on homemade cal-traks. They all look nice, but they dont help transfer weight like they should. So i came up with an idea to link the rear of the frame to the bottom of the axle so that when the axle tried to rotate up (i.e. a really good launch), all of the rotating force will be applied to the rear end of the truck pulling it down and dumping a whole lot of weight in the back end. I'm not a suspension expert so this could be completely useless. But if nothing else, it will be fun to try. I'll be using 4-5/8'' teflon lined male shanked rod ends, one left hand, and one right hand so that the system will be adjustable. The bars will be made from 3/4''x.100''wall round tubing(chromemoly of course). The brackets will be made from 1/4'' steel plate. and all fasteners will be Grade 8 or better. In my opinion, if a grade five did just fine for 20 yrs, exchange it for a grade 8 and forget it forever.
here is my first draft initial drawing which was composed 06/24/2009 at 8:02 p.m..
