Originally Posted by
ff_jeff
A lot of the new guys are stuck on the bottom end thing. Truth is, most cams dont make you ''loose'' bottom end. They just appear to because the top end has much more contrast of the low end. If all you going to do is a cam, and no other boltons period. ''hardly no one does this cause its addictive'' In my opinion I would get a cam in the 218-225/218-225 .525-.580/.525-.580 range. Keep lsa between 112-116. You should be fine.
If you want the most power with a better than stock low end, there is a cam called the ''cheaTR'' cam. Google it. Great cam for stock manifolds. Sounds stock.
