Results 1 to 10 of 31
Thread: TrueTrac Problems
    Apr 2007
    Brewton, AL
    TrueTrac Problems
    I just got my truetrac and motive 410s in and its making noise its like a wining noise. Any suggestions????
    03 RCSB,4.10s,LTs,True Dual Magnaflows, CAI, EFILive, 10K HIDS
    Augusta, Ks
    Backlash set right?
    2004 Buell XB12s
    yeah somethings not set right, take it apart and do it again until you hear no whining
    Augusta, Ks
    Dont drive it till you take it back apart. You dont want to have to buy another gear set.
    2004 Buell XB12s
    wichita falls, tx
    yeah that would be the gears not the truetrac
    Intro Radicalli's
    Pittsburgh, PA
    did you happen to install gear oil?
    is it whining all the time or just at 55-60mph
    Yep. Need more info.
    Apr 2007
    Brewton, AL
    I didnt install it i got a local mechanic to do it. I have talked to many people hes did ring and pinion for and they said they never had any problems but you never know but he has changed it out 3 or 4 times tryin to get the right shim to work then he told me he used a dial indicator to set pinion depth and used the #s on the back of the pinion to find the size shim to use. I know if a rearend is set up right it dont make noise so somethings wrong?
    Apr 2007
    Brewton, AL
    The wining noise is constant on and off the gas it does get louder the longer you drive it so i got it parked until i can get someone to look at it.
