Page 3 of 8 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 75
Thread: Here you go
  1. #21
    The first fast truck I ever drove was a lightning. I wanted one for a long time then I realized I could have a Chevy for the same price and put some add ons on it. I like both trucks and especially the turbo. I bet you like the turbo over the whipple. I sure as heck do.
  2. #22
    Houston
    Quote Originally Posted by ss wrecker View Post
    nice truck man. not much of a ford fan but this is one of the two i'll say i like. the other being my buddies slammed f250 on 24s, f'n fast as hell
    Thanks for the big compliment! This is what I want to get one day! This is the reason I'm here to learn what you are doing to be fast. Then I will have the best of both worlds!
  3. #23
    Quote Originally Posted by Hayhauler View Post
    Well you have good taste that's for sure. You should put an LS1 in your lightning and see many ford guys freak out.
  4. #24
    Houston
    Funny you say that because I wanted to do a Lightning engine on the SS Clone! But No I will keep it Chevy all the way when I get to it! It will be sooner than I thought!
  5. #25
    Houston
    Here are the specs of the JDM's engine long block include:
    • New 2004 Block
    • Steel Crank (1000 HP)
    • ARP Main Studs
    • ARP Head Studs
    • Manley Rods (900 HP)
    • JDM Spec'd Pistons
    • JDM Spec'd Bearing and Rings
    • High Volume Oil Pump
    • Ford Head Castings, CNC Ported to JDM Specs
    • Stainless Steel Shim Head Gaskets
    • 16 New Stainless Steel Valves
    • 16 New Valve Guide Seals
    • 16 New Lifters
    • 16 New Cam Followers
    • Titanium Retainers
    • Factory Keepers
    • Stage 2 Cams
    • New Rear Main Seal
    • 2 New Timing Chain Gears
    • 2 New OEM Timing Chains
    • 4 New Guides
    • 2 New OEM Oil Tensioners
    • 2 New Case-Hardened Guide Pins
    • New Freezeout Plugs
    • Blueprinted and Balanced
  6. #26
    Kewl! A Furd to pick on J/K... No I'm not
  7. #27
    Houston
    Quote Originally Posted by DBTBSS View Post
    You won't be the first! I can take it it's cool!
  8. #28
    Houston
    Quote Originally Posted by mean05 View Post
    you think the lighting is heavy wait till you get a SSS...
    I swear i have seen your truck though, you ever go to the texas mile or hennesy's track in Katy?
    you've gone to katy V? crazy never seen ur truck here or actualy at hennesy track
    awesome lightning my friend just got his back from psi he has stock blower and put down somewhere in the 500's on a slow, tune and is getting 3.4 Whipple, but i am looking forward to getting the SSS done would u be willing to race a 4.8ls motor? lol you would kill me but would like to see that turbo in action!
  9. #29
    Jun 2007
    Oh boy !wtf.
  10. #30
    Houston
    Quote Originally Posted by 408.Luke View Post
    I have only been there for the Houstonperformancedriving events that has been twice last year. I'm up for friendly races but will be about two months by the time it's out and running.
