Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: Gear Problems!!!
  1. #11
    ff_jeff Guest
    Quote Originally Posted by alabamachevy15 View Post
    Well i talked to my mechanic this morning about the gears and he said the 8.5 410s wouldnt fit in my housing! I was just wondering if he really knows his stuff?
    8.5 and 8.6 gears are the same. He sounds full of it. The only way the gears wont fit is if they are lower than 2.76, or higher than like 5.10 or something. IMO, find a buddy that does know what he is doing. And do it your self.
  2. #12
    Apr 2007
    Brewton, AL
    Yea thats what i was thinking hes just full of bulls***! Im going to try to order a truetrac this week. Then me and my dad can put it in.
    03 RCSB,4.10s,LTs,True Dual Magnaflows, CAI, EFILive, 10K HIDS
  3. #13
    Apr 2007
    Brewton, AL
    Does anybody have a write up on a truetrac installation or what all i need to do the swap?
  4. #14
    ff_jeff Guest
    its the same as any lsd or locker...http://www.ls1truck.com/forums/mecha...tructions.html
    this is a write up, but the pics are gone. Ill look for one with pics.
  5. #15
    Jun 2007
    like they said 8.5 8.6 gears are the same.ive even used 8.5 and 8.6 gears on the same eaton posi unit.it worked ,the 8.5s were out of a 80s camaro and i put them in my truck with my 8.6 eaton unit.
