Results 1 to 10 of 11
Thread: If Tire Diameter Increases By 2", What Rear Gear?
    Oct 2003
    If I install tires that are 2" in diameter larger, what rear end gear ratio would I then need to compensate? Is there a formula for this calculation? Thanks
    Circumference of old tire divided by new tire will tell you how much the gearing changes. Multiply that by your current gear ratio and it should decrease in size.
    If you want the same affective ratio then just find the percentage change in inches of tire height and apply that percentage to the gear ratio.
    Hahaha Greg we said the same thing
    I know, I'm a nerd. Circumference is more accurate than diameter.
    yeah with the weight acting on the sidewall the tire isn't round.
    Oct 2003
    Dang! That actually works! LOL... Thanks
    Pittsburgh, PA
    rule of thumb is for every inch you go up or down you gain or lose .010 of gear
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Spring, Texas
    So if I've got 3.42's with a 29" tire and go to a 26" DR, my ratio would be a 3.45?? Do you mean .10 of gear? That would be a 3.72.
    Hurley, Mississippi
    I'm to lazy for all of that here's a good site to http://www.miata.net/garage/tirecalc.htmlhelp out
    '86 Silvy- '06 6.0/4L80E, K&N, 2.5 X-pipe Magnaflows, 20" Foose Wheels, Auburn Pro, 3.90 Richmond Gears, and the list is growing!!!
