Page 6 of 6 FirstFirst ... 4 5 6
Results 51 to 55 of 55
Thread: 1BrokeC10... Motor Knock
  1. #51
    Oct 2005
    Baton Rouge, LA
    Quote Originally Posted by 04 black ss rcsb View Post
    Had a similiar issue with my truck idling very rough.. just like a big cam was in it. When I disconnected the MAF sensor it idled fine. Turned out to be a vaccum leak on the driver side valve cover, near the back. Have you check for a vaccum leak yet?
    Think that is the issue. At least it sounds like it with the hood up. Loud hissing sound toward one area... rear of motor. Will see.
  2. #52
    Mine was doing the same. it turned out to be the hose going to the booster leaking, I fixed that and now it runs fine.
  3. #53
    Oct 2005
    Baton Rouge, LA
    Quote Originally Posted by k10shortbox View Post
    I hear something "hissing" toward the back of the intake, but hadn't messed with it to verify. Could probably smoke the engine and notice right off the bat. Will see. Just wanted get it together before my house went ACTIVE on the MLS. Selling a house with a "dead" vehicle isn't a plus. Besides, I had to move it in order to paint the wall it was blocking.
    I'll dingle around with it sometime this week... HOPEFULLY!
  4. #54
    Well get to dingling with it Dingleberry!
    Smoke that bish and see whatchya got. But before you do all of that madness--go through and make sure your seals are good and your bolts are tight...
  5. #55
    Oct 2005
    Baton Rouge, LA
    Found the leak. Seems there's a port on the passenger side of the intake that is not "open" from the factory. Somehow or 'nother, the tab broke off, and "opened" that port. As a "make-shift" workaround, I took a short piece of rubber hose, slid on that potential vacuum port, and plugged the other end of the hose with a machine screw. Seals the hole for now. Need a permanent solution though.
    With that said, I drove the truck to work this morning (50 miles one way), and had ZERO issues. It's back to it's old self again. Even the part about sucking up fuel at WOT!!!
    So far, so good. I have some pictures of the new block before I cleaned some "kruud" out of it. Will post later this evening.
