Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 48 of 48
Thread: SOO Close
  1. #41
    S.A. Texas
    Hell yeah good times
  2. #42
    San Marcos Texas
    Awesome times David! That MPH is well into the 12's range, just get the 60' down!
  3. #43
    May 2006
    Waco TX
    when the track prep doesnt suck balls, and when the guy with the bronco doesnt show up
    even though I heard that one day yall went out everyone was getting PB's like crazy
    I got an email from them and they said they resurfaced the track or smoething like that
  4. #44
    Aug 2004
    Magnolia, TX
    nice times lil enchilada. keep it together until FEB so i can take it down the track.
  5. #45
    Quote Originally Posted by Red03SilSS View Post
    oh well good then haha. I was worried they were still dumping hundreds of gallons of water into the burnout box
    Quote Originally Posted by 2k5Squirrel View Post
    if you can cut a better 60ft time and get a few tenths off, you can have the truck
    Mar 2006
    13 Flat on a stock converter!! That is bad azz my man! You are coming on strong after the 1/8th. I think I ran those tires at 15 PSI, but then again I dont think I trapped that when I ran a 12.55. Slicks are going to feel diff going down the track and it will take some getting used to. Just hang in there and dont lift, unless of course you see the wall getting real close! The only time I had issues with E.T's skating around at the end of the track was with 8psi. Anyway you can run the pressure at whatever you want as long as they dont spin. Cooler weather and you will be in the 12's for sure! Throw a nice stall in there and a 50 shot and you will be in the 11's.
  7. #47
    Pittsburgh, PA
    bias-ply and radials will sway thats why they say to run bias-ply in conjunction with front bias-plys
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
  8. #48
    And Bryan's truck isn't 3" off the ground like David's. There are a lot of different dynamics between the trucks to explain the air pressure difference. The main point is that you went faster with better 60' each run than the run before.
