SO, What is the best intake for the 4.8?? I am curious. Is it the LS6? Can I use one offa CTS-v
What do you want to do with the 4.8L? You want all out, high rpm HP? If so, the LS6 from a 5.7L CTS-V would be fine...
if anyone in the HOUSTON area wants a LS6 intake i will sale most of the parts AND install everything for you. bring your own water pump and bring your own injectors. i will supply EVERYTHING ELSE AND INSTALL IT FOR YOU.
i'll need a few little parts from your truck intake setup that you will not need anymore, but youll be taking my modified parts from my current setup.
anyone interested?
how much?
Thanks for answering my question up top. Its all I needed to know.
Check this out!
http://www.proheads.com/specials.html
