Got my LT's and am ready to put them on, but I want to make sure I get the torquing pattern down so they don't leak? Also anybody know the ft/lbs? Thanks!
Mike
2000 RCSB
Get them all snugged up first, then start in the middle and work your way out.
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
and watch out on tightening these they snap easier than you'd think, i have know idea the torque specs but eveything else is 22#s, let see if anyone else chimes in and says a good torque for em.
11 first pass, 18 2nd pass.
05 , 6.0L , 22 ft lbs then 90*(degrees) , then 70*(degrees) , works out to around 75-80 ft lbs .
ARPs say 85 ft lbs .
Now what is a tune again?
Comp Cam 54-412-11 , Int:265, 212, .522 , Exh: 271, 218, .529 , LSA 114 , Longtube , CAI (Vararam) , TransGo HD2 shift kit , tuned by me with EFILive
Huh?
All of the header bolts would break off in the head at that spec. I got my post from GM Service Information for an 04 but an 05 is the same. I think you're thinking of the HEAD bolts.![]()
Duh , yeah header bolts .
I went to the Evelinwood Sped Reding Schul .
Yeah 132 in lbs (11 ft lbs) , first then 18 ft lbs .
