I say do a single 3" into a Hooker Header Aero Chamber muffler, and then dual out of it. It will give you a great sound, and it has the best flow of all those mufflers. However, if you do not want the Hooker, then go with the classic single in /dual out Flowmaster 40 series. Great sound, but doesn't flow as well as hooker.
Both of these will be coming off a y-pipe. True duals isn't necessary to get a performance increase. The above setup will work just fine, and run ya about $250. All you have to decide is if you want the pipes to exit out the rear, or out the corners at a 45 degree angle. I prefer the corners so you can hear the exhaust better, but you may like the look better of the straight out the back pipes.
Ron
FOR ALL YOUR WHEEL, TIRE, AND ACCESSORY NEEDS
CONTACT: EPLEY'S TOUCH OF CLASSIC 1-270-843-6892
OR TO GET ME PERSONALLY CALL: 1-615-943-6514
2000 Chevy Silverado 4.8L RCSB: smoked UPD, Flowmaster exhaust, De-screened MAF, Nelson 93 hot tune. Upcoming installs: trans-go shift kit, Eaton posi, billet servo, ported and polished throttle body...Near future: 6.0/4L80E install with 150 wet shot
