I'm looking to get my front end level with the rear. It's a 2004 ECSB. There are a few brands that all say "they are the best." The brands I'm looking @ are Tuff Country, Daystar, and Readylift. Any info would be much appreciated.
Thanks
Thanks
You just want to raise just the front end? I would just turn the stock keys. They will probably go level. Those kits are just new keys that have a little more turn to them. Just turn the keys up even on each side to where you like it. Its usually not a good idea to raise anymore than 1.5 to 2in. It will stiffen your ride somewhat, and pay attention to your cv axle angle. If it's too steep you'll run into problems down the road.
John
Four by Four to the floor.
My truck is 2WD and has coilovers, not torsion keys. The kit consists of (2) 2 inch spacers that go under the springs.
WHOA lol sorry man totally missed that! Used tuff country before on nnbs 4x4 that's a spacer but obviously not the same one. Good quality product and easy to follow directions is all the help I can offer sorry man.
John
y not drop the back? 2in drop shackles form beltech are like 40 dollars
I had thought about that, but I live and work in a rural area and it really wouldn't fit in around here. LOL! That, and my driveway resembles what some might call a ski slope and I would hate to have the a** end or exhaust scrape the ground everytime I pulled in or out.
I'm getting new tires tomorrow. 255-70/R16's. Think 265's would be a little better? Right now I just have 235-75/R16's
i think 265/70s are about 31-31.5", if you're going to do coil spacers i would go ahead and get the 265s now. they llok fine on a stock height truck and will look even better once you do the 2" lift.
a little taller, but here's a pic of my 2WD on 4" spindles and 265-70-16s:
http://www.ls1truck.com/forums/pics-...tml#post190268
Might have to do that. So....what is the difference between Daystars and Readylift's? They look the same but there is a $100.00 difference between the two. Is one better quality than the other.
