Im going to lower my truck and im confused on somthing. Do i need the carrier bearing relocater or pinion shims, if so what degree? 99' ECSB
I am not positive but I dont think a 2/4 drop should affect it! I think you should be ready to roll!
2000 SILVERADO RCSB STOCK LS1, CAM, BOLT ONS
7.93@85.21
12.61@105
http://www.ls1truck.com/forums/my-ga...silverado.html
Check out my PhotoBucket Page!
http://s174.photobucket.com/albums/w114/carfreak07/?
BIG BURNOUT VID IN THE SS!!!!
http://videos.streetfire.net/video/7722e80...d29a3318cde.htm
when I did my 4" drop in the back my kit( Hotchkis 4" Lowering Leaf Pack With Special Carrier Bearing Bracket) came with the carrier bearing relocater, did not have to add shims. no problems drives great
Yeah, a 2/4 drop should need the shims. If you were going lower, then it would be affected and you would need to adjust a few things. You thinking about spindles up front, hangars out back?
If you are gunna drop it--a 1/2 is not noticeable. If you are gunna do it--go with at least a 2/4. Coils are not bad...just getting the upper/lower a-arms back in kinda sucks. You should go have a professional look at it soon if you are getting such bad drivetrain vibration.
