Results 1 to 7 of 7
Thread: 08-501-8 comp cam?
    Mar 2004
    KY
    08-501-8 comp cam?
    Who knows about this Cam? lopy idle? performance? Stock L31 with exhaust is what its going in?
    96 Silverado rcsb
    5.7l Vortec
    Exterior: 2 inch drop shackles, Centerline Titan 20" Wheels, clear lights, Debadged.
    -Exterior to come: 2-4 drop, Tinted windows, Cowl hood, Green Calipers
    -Performance mods: Flowmaster True Dual exhaust
    -Performance to come: Tune, CAI, Cam, Spray, Posi, gears, stall, headers.
    L31 - the last of the Gen I's. Those engines had the good Vortec heads and intake manifolds. The cam you selected will work well with the engine - strong mid range and will pull hard into the low 5000's RPM. It will have a mild lope, but still produce high vacuum at idle. Depending on the vehicle weight, you may need more gear or a higher stall (if auto). The cam has fairly aggressive lobe profiles and 22 degrees more intake duration than the stock cam, so expect about 40-50 more HP. You should be right at 300-310 HP at the crank.
    Kilgore, TX 75662
    that would be 212/218@.050. Lift with 1.5 rockers is .488/.495.
    In a stock L31, I think it would work very well.
    The L31 is almost identical to the iron head LT1. The LT1 has a little higher compression ratio and the LT1 intake.
    What gears and what size tires does the truck have now?
    Mar 2004
    KY
    i have 275/55r20 and 3:42 gear. i have flowmater dual exhaust
    96 Silverado rcsb
    5.7l Vortec
    Kilgore, TX 75662
    I still think that cam would work well, but it would like more gearing. With those tires and since you've already got 3.42s, I would jump straight to 4.10s.
    Mar 2004
    KY
    how lopey is the idle gonna be?
    96 Silverado rcsb
    5.7l Vortec
    Kilgore, TX 75662
    probably not as noticeable as the LT4 Hotcam.
