Results 1 to 10 of 22
Thread: harness
    harness
    I have a 6.0 that im installing in a 93 chevy and when i bought the engine the harness was cut, It was cut on the rear right side of the intake. its about 19 wires...dont see a MAF plug, transmission plug, vss, or 02 sensor plugs.
    can anyone help me out here and tell me what these wires go to.
    heres the pic
    kind of a double post, its in my intro but figured it belonged here.
    93 ECSB...lq4 6.0 swap, 255 walbro,cai, ported tb, shorty headers, 3" exhaust, tune,electric fans, NX wet kit 100 shot, 2/4 drop, beltech shocks, boss 335 22's, 295/30/22...looking for a cam.
    anyone???
    May 2004
    I'd recommend using a volt meter and looping the wire to the PCM connector and marking each wire from there. It will take about 15-20 minutes but you'll know for sure where each wire goes.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    to complicated, im lazy. besides dont have a wiring diagram.
    figured some one here would know what it goes to, i guess i'll just have to go to a dealer and look under the hood of a used ls truck.
    May 2004
    We can help you with wiring diagrams but if you'd rather look at another vehicle go for it.
    97 GMC, 2002 LS6.
    You're up sh!t creek without a paddle unless you're willing to help yourself a little. NITROUS knows his wiring and I can help too but we need help from you to help you, dude.
    Too lazy? Wanna buy fuel for travel or a plane ticket for someone that can help?
    Let us know.
    lol, just pushin buttons to get a response.
    Yeah i need a wiring diagram, pretty good with reading em too.I've heard ls engines are pretty easy to wire yourself. so i've read anyway.
    Before i get into this harness i have a question. Will the ecm i have work with an older 4l60e (93 rwd)
    the ecm and engine came out of a 2002 2500 series 4x4
    dont know if the connectors or wiring would be the same as an 4l80 or 60.
    done see why they would be different connectors
    wichita falls, tx
    you are gonna need to get a pcm pinout for the truck the motor came out of and trace those wire back to the pcm and see which pins they go to and go from there.
    i have pretty much a whole harness at the shop so whatever plugs u need i prolly gotem
    Intro Radicalli's
    Quote Originally Posted by rammor02 View Post
    4L60 and 4L80 have the same connector just a different pinout. Also the 80 has a second VSS
    wichita falls, tx
    yeah, the 80 harness will not work with a 60, the 80 has less wires in the main tranny plug
    Intro Radicalli's
