Results 11 to 20 of 23
Thread: overheating issue
  1. #11
    Southeastern Wisconsin
    dont know what to tell ya, i have a cam, and headers, and e-fans, i run mine all day long, in traffic, it was like 96 out the other day, and never even went past the normal operating temp. i would definately check to see what your coolant level is like, maybe try flushing the system with a hose.
    I have to work on my heater core, its getting down to the 50's at night and im going to need heat when the snow hits.
    1999 GMC Sierra SLE ECSB .... 5.3L w/ Slight Performance Tune / True Duals with Flo Pro Glass Packs.
    Project ''Bad Company'' Future = 6.0L (Forged Internals) / Boost (TVS) / 4L65E LvL 5 / AWD Conversion / Full LT's with Cats / Methanol Injection / Lowered 2" / SS Rims / Frame Up resto
    Officially Employed!!!
  2. #12
    The crank is what drives everything else...
  3. #13
    Missoula,Montana
    Check the thermostat.They sometimes hang up.If there is a shiny spot on the inner pole replace it.
    '00 1/2 TON ECSB 5.3L 4L60E
    K&N Filter,Gibson Exhaust,Superchips Programmer,Billet Servos,'03+ Taillights,White Door Handles,Carbon Metallic Grille Emblem,6000K HID'S
  4. #14
    Aug 2003
    Spring, TX
    well i checked my fluid level and it was a little low.
    i wouldn't think that being less that a cup low would make it start overheating.
    since i filled it up i haven't seen the temps go up.
    correct but by putting a smaller crank pulley doesn't that speed up the other pullies?
    maybe i'm not getting the science behind the UD pulley.
    can you explain to me how the UD pulley works? (very serious)
    i'm here at work asking a co-worker and both of us are a little stumped. LOL
    -leo-
    2009 Silverado CC - 6.0L L76|6l80e|3.42s|4/7 drop w/ helper bags
    01 silverado ecsb - (RIP 04/2009)
  5. #15
    Schertz, Tx
    Think of it this way...if two cars are going around the same corner, the one on the outside has to travel a little faster to stay in the same relative position as the other car. If you increase the size (radius) of the corner, the outside car has to travel even faster to keep up. On a UD pulley, you are effectively decreasing the "size of the corner"...since the outside diameter of the pulley has to travel the same speed as the inside diameter, making the pulley smaller effectively reduces the "outside velocity". That's why UD pulleys are popular...you don't use as much energy/hp turning them.
  6. #16
    Aug 2003
    Spring, TX
    so the rotating speed of the crank is constant?
    but the speed of the pulley is changed....correct?
    am i getting warm or i am cold? lol
    -leo-
  7. #17
    Schertz, Tx
    The crank speed will obviously change with the speed of the engine, but the crank pulley speed will also change appropriately. Regardless if it's spinning at 1 rpm or 6000, the outside edge of a smaller crank pulley will travel slower than the outside edge of a larger crank pulley. Since this is where the belt travels, the belt will travel slower around a smaller crank pulley than a larger one. Here's a link to some good info on underdrive pulleys: Underdrive pulleys - Wikipedia, the free encyclopedia
  8. #18
    Aug 2003
    Spring, TX
    cool thanks for the link!
    -leo-
  9. #19
    Sallisaw OK
    in the past when i had problems like that i would turn my heater on high/hot to help remove any heat from the engine. not pleasant in 100F weather but if the air coming out of my heat was not burning hot i knew the coolant was really low.
    i would say get it hot like that again and pop the hood to see if the fan is running fast. if you get elec fans and have an overide switch to get both fans on high it would probably get rid of the issue.
    but i would also change the thermostat because it sounds like it wasnt fully opening. full flush and new thermo cant hurt.
    1996 gmc ext cab short bed
    6.6L 4l80e
    MY GARAGE
  10. #20
    When the DRIVE gear or pulley is decreased in size, everything it runs will slow down. If the DRIVE gear or pulley is increased in size, everything it drives will speed up.
    If a DRIVEN item gets a larger pulley, it (and only it) will slow. If a DRIVEN item gets a smaller pulley it (and only it) will speed up.
