Results 1 to 5 of 5
Thread: Pulley question
    Mar 2004
    I just thout I would ask this question even thou I already installed my pulleys 2 months ago. But anyways, I bought the ASP cranck an Alt. pullys an I was just wondering if the pulley for the Alt. is supposed to be Bigger that stock for more HP or is I suposed to be Smaller. I have heard that there are 2 diffrent Alt. pullys one for more HP an one for more Alt. power to power your amps an speakers. My kit came with the crank pully an the bigger Alt. pulley. Is this the right one for more power?
    Apr 2004
    Dallas
    my guess is, dont change it from stock, i didnt on my s-10 and the amps went down, HP went up. My logic tells me that the bigger the alt pully, the more the alt gets....if that helps any. they give you a bigger alt pully so your alt will still produce the same as with out the power pullies altogether.
    http://students.csci.unt.edu/~wwb0002/Pics/truck1.jpg
    Current:
    -- 8mm wires -- Air-Raid Intake Box/Filter -- Air-Raid Intake Tube -- Stage 2 ported TB
    Future:
    -- AS&M Headers --> 3" X-Pipe --> 2 Race Bullet Mufflers
    -- Cam 216-220-525-532-114
    -- Tuning
    Jasper, Ga.
    The bigger (new) Alt. pulley is so you would not loose voltage after going to a smaller main pulley.
    1999 Silverado 1500 Ext. cab Red 2/4 hotchkis drop & swaybars, bilstein stocks, AR626 & 404 Nitto's, Yank converter, ASM headers, ASP underdrive pulley, Taylor wires , free mods VCN 2000, Nelson Performance tuning
    2002 Red WS6 M6; Flow master K&N
    Apr 2004
    Ahhhh you dudes are upside down. SMALLER ALT pulley = MORE ALT OUTPUT/
    more alt sucking power. The smaller pulley spins the alt faster.
    And on my F Bod the alt was not producing enough with the smaller crank (under pulley) and sitting at the light the car was surging and lights where dimming and
    A/C on ,made it worse. I gave up on the whole deal.
    mostly stock 04 silverado 1500 CC
    Gibson Headers and Sport truck Cat Back
    5.3L 3.73 Detroit True Trac
    165F therm,HpTuner
    07 17" Sierra wheels
    Dark Grey
    Apr 2004
    Dallas
    Current:
    Future:
    -- Tuning
