Folks are there performance gains from this swap? 5.3 heads on a 6.0 block.I have a 5.3 with 133k + miles on it and it has a death rattle in the bottom end. I am swaping the 5.3 for a 6.0 in a 03 Z71
no performance gain by running the heads really....you get more compression but less flow through the heads so it balances itself out power wise
Thank you. I have the heads now on the 5.3. I was wondering if I should go with a long block or short block in the 6.0 from a cost point. The heads would have to be reworked new guides and seals because of the miles and I could have a port job done at the same time for better CFM. I just didn't waste money if there is no gains to be had. It seems that we will plug and play the 6.0 as I have a K&N air box and the Superchips flashpac tuner and duals already on it.
i would just pick up a 6.0 long block and have the whole 6.0 reworked...then just use the intake an all the accessories from the 5.3...but you also may want to get a real tune from Nelson because the 5.3 program will run a little to much timing for the 6.0 and you may get detonation from it
Mean05,
Is this something the Superchips can help with. The tuner I have is downloadable via. the internet and I can get them to write a program for it. I have already talked to those folks and they say its no problem.
i am sure they can help you out...if they say it's no problem then go with it...i am just not a big fan of handheld tuners....
Mean05
Is Nelson's tuning done on a laptop or dyno. How do I get in touch with them?
Thanks for the help
well it's technically done on a laptop...but if you go to his shop he can dyno tune it for you.... nelsonperformance.com also he is on this site (farmtruc) you can send him or melissa a pm on here....always glad to help
I just purchased a 6.0L Long Block for $800 and im going to swap the 317 heads for LS1 241 heads for the compression on my 5.3L so im kinda in the same boat lol. But in my opinion you should look around and find out what you plan to do to your truck in the future and work towards that. hope that helped Good Luck,
05 Silverado cc LQ9, 220 220 .581/.581 114+1 LSA, Pacesetters with Ory, TBSS Intake w/ 90mm TB, Comp roller Lifters, LS7 1.80 rockers, LS1 Heads, Transgo HD2, Vette servo, 160 stat, custom 3inch exhaust, and Nelson Tuned:
5400lbs- 13.62 at 100.46mph - Dynoed at 360rwhp - 375rwtq
ha too bad i have 241s alrdy and dont really need 2 sets lol but im selling the 317s if ur intrested pm me
