Results 1 to 7 of 7
Thread: best oil pump?
    Jun 2007
    best oil pump?
    hey guys im doing alot of changes here soon .i only have about 10k on this motor but it has low idle oil pressure as far as im concerned.like 25-30lbs most of the time .as soon as i give it a tap of the gas it progresses up to 70 80 lbs so i just want too be safe and install a excellent oil pump.what cha got for me guys.it just weird it is a 06 motor.always been this way.brand names or links would be nice.thanks ahead
    Oct 2007
    Bandera, TX
    I put the melling high pressure high volume pump on my 6L. I will let everyone know how it all works. It is a nice pump, and had no issues with it clearing my comp billlet double roller timing chain. It will be running within a couple weeks.
    single digit street truck
    for build info
    Jun 2007
    let me know,thanks
    Jan 2012
    Quote Originally Posted by TurboMic View Post
    Just put the hp/sv on my 6l today. I used the shims that came with timing set. Pump to chain is great. Pump to front cover is bad. I will try it tomorrow without the shims.
    Im running the Melling in my 5.3. I used the low pressure relief spring and it sits at 40 psi at idle and like 60 at cruising and 80 at wot.
    Quote Originally Posted by cottontop11 View Post
    shims with timing set? or shims with pump? either way youll need to modify the inside of the timing cover, the pump will hit the chain if the shims arent in place. i know with a melling anyway!
    wow this thread is over 4 years old
    Simple: 408 on steroids!
    single digits coming soon!
    Jan 2012
    Yeah i realized it was old a little late. I was searching oil pump and found it. Sorry to kick up old stuff
