I got my NELSON tune on wednesday, and everyday it gets better and better. Thank you ALLEN. However, now my tranny temps are about 30-40 degrees higher. The temps are now around 195-205. Is this normal???
2000 SILVERADO LS , SBSC, 2WD, 5.3, 3:73 POSI, TCI 3500, BILLIT SERVOS, DEEP ALUMINUM TRANS PAN, 160 T-STAT, 34" RADIATOR, 16" ELECTRIC FAN, GIBSON SHORTIES, 3" OPEN EXHAUST, JANTZER T.B., K&N GEN 2, ASP PULLEY, NELSON TUNE, NGK TR55, TAYLOR WIRES, 100 SHOT DRY N.O.S., 5-7" BELLTECH DROP, BOYD CODDINGTON TIMLESS 6(18X8, 18X9.5), TOYO PROXES T1S(255/45/18, 285/40/18), ALL SYNTHETIC FLUIDS, KATZKIN LEATHER, T/A GIRDLE & STUD KIT, DYNATECH ALUMINUM DRIVESHAFT, 250 LBS OF WEIGHT REDUCTION, STREET SCEENE MIRRORS, SIR MICHAELS ROLL PAN, AND MORE IN THE WORKS.
if you have no tq then it will climb a little. if i get into mine a few times then mine will get to around 180 to 195. i have the b&m supercooler that is 11" X9". it is a bad ass cooler.
formerly 02denali 12.79@107
02 did you bypass the rad when you put in the B&M. I have the factory cooler and my temp around 180 to 200. I bought the 28000 B&M cooler but not sure if its better to bypass the rad or not.
2015 GMC Sierra RCSB Z71 5.3
no i did not i have it still going through the radiater
