Results 1 to 8 of 8
Thread: 5.3 Daily driver needs more power.
    Feb 2008
    Mississippi
    Newbie here for MS.
    I have a 2006 ECSB 2wd Silverado. It is my daily driver. Could y'all point me to some threads for budget mods/bang for the buck.
    I have a drop in K&N filter. Is a truck CAI worth the $$$ ? Favorite brands?
    I have a Flowmaster 40, but I really want to go with either the Magnaflow cat back or the Corsa Sport. Opinions?
    I hope to be swapping my 3.23's for some 3.73's very soon.
    To get a little more go power while staying with 87 - 89 octane what do y'all recommend?
    Maybe rocker arms, or just go with a cam? A tune?
    Thanks all.
    2006 ECSB Silverado - 5.3 Auto, 2wd, Escalade Handles inside and out, removed badges and moldings, K&N drop in, Flowmaster 40 w/turndown, 2" rear shackles, factory 6 Disc head unit from 03 SS, GM 20's.
    2003 Grand Prix GTP - Slp SC pulley/modified air box
    1968 C10 Project - http://67-72chevytrucks.com/vboard/s...d.php?t=269999
    San Antonio
    Definately get a good tune, will work wonders on the truck.
    Oct 2007
    Spring, Texas
    Mods
    Corsa = awesome,
    Shorty headers i'm sure some will disagree ( Ceramic Coated)
    3.73 good idea
    true intake not just a drop in i run an AEM brute force
    Nelson tune for whatever octane you want to run obviously 93 = best gains
    underdrive pulleys
    low resistance plug wires if running headers get high heat resistant also
    e-fans will help performance and mileage i think
    shaner ported & polished throttle body great mod for stockish vehicles and highly modded as well
    remove cats if possible in your area and have tuner delete rear o2
    Just some stuff i thought would help out
    Good Luck
    Oct 2007
    Spring, Texas
    a tune , P&P throttle body , corsa, and gears will make you very happy
    Spring, Texas
    There's a ton of stuff you can do and still have it as a daily driver. Note, everything in my sig and I have a 35 mile one way commute to work everyday averaging 18-20 mpg......some miles are faster than others A good tune is definitely the best bang for the buck!
    Oct 2005
    drinking your alcohol
    CAI (i have the volant i likey), e fans (if you dont have em already), tune <-- best bang for buck, gears if you want some pep to your step, underdrive pullies (i like mine), longtube headers and a y-pipe
    DamnYankee: my nana failed
    S.A. Texas
    x2 on the volant. run the pacesetter long tubes, nelson tune for sure good lookin truck buy the way
    1.) If you have the cash, do Corsa.
    2.) No need for e-fans fellas--he has an 06.
    3.) Underdrive pulleys--harmonic balancer AND alternator
    4.) Pacesetter long tube headers with 3" ORY
    5.) I LOVE my Series 77 K&N CAI
    6.) Either a P&P stock TB or a 80-85mm BBK TB
    7.) Cam kit--no need for rockers, IMO
    8.) Stall
    9.) 3.73's and a Detroit TrueTrac
    10.) A custom tune
