Results 1 to 10 of 17
Thread: what about the ATI procharger kit?
    Apr 2004
    1. its intercooled
    2. Easier install than radix
    3. more overall power potential
    how bad is the lag in power?
    are ATI's products considered as dependable as the Radix?
    thanks guys, as you can tell I'm still on the fence about which one to get.
    2005 Chevrolet Silverado 2500HD ECSB 2WD
    365 CID motor built by "Rex", Magnuson TVS 2300,WCCH StageII LQ9 heads, EDC Cam, SW Headers, Magnaflow Exhaust, CPT 4L80E, PI 2800 TC, TRACK: Real Racing 16x12 wheels, M&H DOT Cheater Slicks, STREET: Intro Pentia 8 20x10 wheels, BFG KDW's
    2008 Nissan Frontier KC VQ40 V6 AUTO 2WD.....Daily Driver
    2002 Honda CBR954RR
    Mar 2004
    Springfield
    I'm not too familiar with ATI products, or radix for that matter. But I do know that almost anyone I meet with a truck that has a s/c, its a radix or procharger.
    Personally, I would rather have one of those STS Turbo kits that Allen is considering selling. They are such a sleeper mod. If anyone looked under the hood they would just think you had a really big air intake. Especially since the turbo is mounted under the vehicle.
    http://ststurbo.com/turbo_vs__supercharger
    Check this link out.
    FOR ALL YOUR WHEEL, TIRE, AND ACCESSORY NEEDS
    CONTACT: EPLEY'S TOUCH OF CLASSIC 1-270-843-6892
    OR TO GET ME PERSONALLY CALL: 1-615-943-6514
    2000 Chevy Silverado 4.8L RCSB: smoked UPD, Flowmaster exhaust, De-screened MAF, Nelson 93 hot tune. Upcoming installs: trans-go shift kit, Eaton posi, billet servo, ported and polished throttle body...Near future: 6.0/4L80E install with 150 wet shot
    Dec 2003
    the boost lag isnt as bad as everyone says. It all just depends on what your trying to do. If you want somthing thats good for towing and you want alot of low end then go with a radix or whipple. If your strickley racing and performance go with the procharger. Procharger has a air to air intercooler wich is more effieciant then air to water like the radix uses. I was running 12lbs of boost on a stock motor with full timing. I could have ran 14lbs and i might have had to pull a degree or 2 compared to whipples pulling 10 degrees. On my truck the procharger was the perfect fit i put tuns of timing in the low end just to get me out of the whole till about 2k rpms then boost kicked in and the truck would just continue to pull. I never bought a stall to that would fix the whole lag problem right there. My buddie put a ridix on his truck and weve ran into a couple of problems with that. He put a 6.0 motor in it with 8 to 1 compression with all forged internals. he bought the radix fo it and he intended to run like 20lbs of boost. The problem is that no one makes pulleys over 9lbs, And the compressor is too small for the motor to the blower dosent kick into boost till 3k rpms. we were going to swap out the radix compressor and put a whipple one on it becuse the whipple compressor is a better unit by far. the radix uses a true roots style compressor that prouces way to much heat. whipple superchargers would be a great kit if they were intercooled. But we have decided it would be alot easyier and alot more performance if we sold the whole radix kit and went with a procharger with a f1 compressor. He should be able to run like 25lbs with that set up. the radix is a good kit for stock trucks for overall power but if your going for track times I think procharger is the way to go. Look whats on the fastest ls1 in the world its a procharger.
    old set up: 2002 chevy 5.3, procharger 12lbs boost, asm headers, ls1 edit, flames, 20inch budniks
    New Set up: 2004 chevy 5.3 ext cab, 12 inch twisted suspension lift, 36's, exhaust.
    future mods: 150-200 shot, ls1 edit, air intake, stall, 5.13 gears, 12s or bust
    Apr 2003
    Man, wouldn't there be high losses with that kit? I mean, its damn near the back of the truck. The boost gauge would be right at the inlet right, I couldn't see in the pics (not sure what to look for). I guess that helps with not needing an intercooler? Why go all teh way back like that? Seems like it's asking for trouble in terms of road debris?
    Andrew
    Andrew
    2001 Silverado 6.0 RCLB - Home Page - 4.8 to 6.0 Swap
    Nelson Tune, Comp Cam XR265HR, Pacesetters, Hotchkis Sways, 3.42, Eaton Posi, Transgo, LS1 Fans, Magnaflow, Eagle 219's 18x9.5, Fold-a-cover
    Dec 2003
    how will that kit work with a low truck?
    Apr 2004
    blown 02, do you have any pics of the install?
    also, how do the stock injectors hold up?
    2002 Honda CBR954RR
    Dec 2003
    i didnt take any pics of the install. The stock injectors hold up fine. Every thing bolts right up on the kit its just time consuming
    Mar 2004
    Springfield
    Andrew
    I know the setup looks odd, but read these FAQs and it will answer any questions u have. I thought the same thing about the delay but according to them it won't be a problem.
    http://ststurbo.com/faq
    Mar 2004
    Springfield
    This is a quote from STS Turbo FAQs page:
    What about ground clearance with the turbo down low on LT1?
    Ground clearance hasn't been a problem as all of the kit sits higher than the stock equipment. I've cringed a few times going over crap in the road or over nasty speed bumps and stuff, but have never hit anything. The new LS1 kit has a couple low spots on the charge air piping but both spots are at the wheels so the car should pick up as the wheels go over bumps and give it added clearance.
    Mar 2004
    Springfield
    This is why you put it "all the way back there".
