Thread: Injector ?
    Jun 2007
    Injector ?
    Lets Try This ,i Guess I Need 60 Lbers So ,my Problem Is What The Heck Ones Will Fit Our Vehicles,plug And Play,i Dont Want Too Change Plug And Crap If I Dont Have To.theres Just So Many ,y Cant Anything Just Be Easy?theres Long,short, Impedant ,12 -200 Lbs ,20 Brands,i Just Want Some Reasonably Priced, Because Price Of These Things Are Wide Ranged 2,60 Lb Injectors For My Truck!any Links Or Any For Sale Id Appreciate It ,thanks Ahead Guys.
    Jun 2007
    good morning
    You have to do clips, the 42's are the largest available that are a direct fit.
    http://www.nelsonperformance.com/pro...1injectors.jpg
    Jun 2007
    thank you i see ,as i read last night i startied realizing that was the case none of them were looking too familiar.now what do i look for when you say clips ,im assumming these are some type of adapter plugs,please correct me if im wrong ,wich i probly am?thanks.
    Aug 2005
    St. Anthony, Indiana
    Nelson has the clips and injectors. Give them a call.
    Jun 2007
    so i take it that you have to just splice these into my existing harness?please aloborate.and do you carry the inj and the clips.pm me with price please.
