Results 1 to 10 of 13
Thread: Tire & Rim help needed
    May 2007
    Oshkosh, WI
    I'm running mid 600's at the rear wheel in a 1996 GMC K1500. I want to run it down the track this spring but need a good set of tires and rims under it. I don't think the Michelin AT's will cut it. I'm also interested in the widest tire on the front and the back I can fit without trimming. Any help here woud be greatly appreciated.
    Mar 2006
    Mesquite
    Mickey Thompson ET Streets work good for most guys.
    May 2007
    Oshkosh, WI
    Yes, I've looked at those and the ET Street Radial. I think I like the radial. The only thing I don't like is the wet traction. I probably should have clarified that I would like to run these around town also. The truck is driven a lot in the summer.
    What size would you recommend?
    Mar 2006
    Mesquite
    Not sure on sizes, buddy - just know at the track a lot of guys run the MT ET Streets. That's about as far as my knowledge goes.
    May 2007
    Oshkosh, WI
    NP, any and all input is beneficial.
    I would try and keep you stock setup for the street and then do some DR's for the track--similar to the ones Yankee said... You could probably do with some 28" or 29.5" at the biggest. I think there are some 26.5" out there, but those may be too small. Are you running 2WD or 4WD at the track??
    Apr 2005
    MT Sportsman SR
    Gone, but not forgotten!
    May 2007
    Oshkosh, WI
    I'll be running 2WD until I get the Atlas transfer case installed then I will be doing 4WD runs.
    May 2007
    Oshkosh, WI
    Do you think these would fit?
    Mickey Thompson Sportsman S/R
    28X10.00R18LT for the Front
    28X12.00R18LT for the Rear
    May 2007
    Oshkosh, WI
    265-75R16
    The stock tire size data:
    Sidewall Height: 7.82
    Section Width: 10.43
    Overall Diameter: 31.65
    Circumference: 99.43
    Revs per mile: 657.19
