Results 1 to 10 of 10
Thread: Help...No Oil Pressure
    Aug 2004
    Magnolia, TX
    4 times today while trying to start my truck i had NO oil pressure. once i even checked it with the Interceptor and that read 1. the last time i had to kill it 3 times before it would read any oil pressure. i also did one WOT and it read 98 on the Interceptor.....Help
    Either your sending unit has crapped out or your oil pump is heading south... Let's just hope it's the sending unit...
    San Marcos Texas
    Does it sound any different? If the engine sounds normal then the sending unit has gone bad.
    Aug 2004
    Magnolia, TX
    Quote Originally Posted by GMCwantsLS1 View Post
    sounds the same.
    San Marcos Texas
    The sending unit is behind the intake. It will be easier to do if you take off the intake first.
    Aug 2004
    Magnolia, TX
    will i need new gaskets? if so that's going to take some time. what about a bad sensor? it sucks not having a dealership over here so i could get my shit fixed under warranty.
    Nov 2006
    Mesquite, TX
    no need for new gaskets they are reusable
    Aug 2004
    Magnolia, TX
    alright...just went out and tried it again. it's about 45 outside, said "low oil pressure" for about 2 secs and then it was fine. cold start idle @ about 750 RPMs and oil pressure was reading 40-43 on the interceptor. oil level is fine. do you think a sensor could be going bad? wouldn't the Interceptor DTC function pick up on that?
    Apr 2005
    Quote Originally Posted by 2k5Squirrel View Post
    I don't think the sending unit can set off a DTC.
    If it is acting funny, replace it.
    Gone, but not forgotten!
    San Marcos Texas
    I had one on my old truck with the 305 at idle it would show 0 oil pressure. Replaced it and it went back to 45 at idle. It won't throw a code that I know of. The Interceptor, gauge, and the PCM all read oil pressure off of the same sending unit.
