Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: alternator
  1. #11
    Jun 2007
    If your getting that bad of a draw when the fans kick on you probably have a weak battery. I'm not saying it's bad but just week. I'm running underdrives on mine and even at normal driving RPM I only get about 13 volts max of charge. It's normally about 12.5 volts or so and I know exactly what your talking about when the fans kick on. I've seen the load it pulls, both my fans kick on together, but I've never dropped below 12 volts. Get a stronger battery! Anything less than 12 volts is a brown out condition and could cause damage to other electronics.
    98 GMC ext cab, 02 LS1, Nelson Tune, S&P headers, cutouts, underdrive pulleys, LS6 intake w/ 85 mm intake, 6/7 drop, 20x10 MB wheels, shift kit w/ servo, 3.42 rear w/ true-trac
  2. #12
    Apr 2003
    Mansfield, Texas, USA
    Thumbs up
    There is a reason GM installed 145A alts with the trucks with factory efans.
    Install a 145A unit, OVERdrive alt pulley, problem solved.
  3. #13
    Quote Originally Posted by Hit Man X View Post
    Exactly...
    I have the stock 105A unit and with a crank and alt pulley (with both fans on), it pulls 14 volts all the time... If my alt goes out, I will def. switch to the 145A unit.
