I was wondering if anyone knows the cost of this project without the price of the car and the price with and without the price of the block. here is the parts list
COMPONENT MANUFACTURER PART NO.
Cylinder block GM Perf Parts 24502503
Crankshaft Crower S95120
Connecting rods Crower SP91202
Pistons C&A P-12-10
Main bearings C&A M-350-STD
Rod bearings C&A R-3272-STD
Cam bearings C&A C-3500-STD
Ring set (ZGS) C&A RS-34ZX4.005
Head bolts ARP 134-3601
Main studs w/tray ARP 234-5601
Oil pump stud ARP 230-7001
Oil pump drive ARP 134-7901
Cam bolt kit ARP 134-1001
Rocker arm nut, 7/16 ARP 300-8245
Oil pan stud kit ARP 434-1901
Accessory kit, hex ARP 534-9601
Flywheel bolt kit ARP 100-2801
Assembly lube ARP 100-9903
Camshaft Crane 11SR00043
Lifters, roller Crane 11540-16
Pushrods Crane 11621-16
Timing set Crane 11984-1
Valvesprings Crane 99893-16
Retainers, titanium Crane 99654-16
Keepers Crane 99094-1
Cam stop button Moroso 60460
Cylinder heads AFR 190
SuperRam EFI system ACCEL 74131
Fuel injectors ACCEL 74606
Plug wires, 8.8mm ACCEL 8031
Timing chain cover Edelbrock 4242
Water pump Edelbrock 8811
Damper Pro/Race 64262
Pulley kit March 6070
Head gasket Fel-Pro 1010
Pan gasket Fel-Pro 1818
Intake gasket Fel-Pro 1205
Header gasket Fel-Pro 1404
RACE set Fel-Pro 2702
Thats the exact parts list copied straight from they're site http://www.hotrod.com/techarticles/302_sma...ild/index1.html
