Thread: TCI trans pan
    Aug 2005
    St. Anthony, Indiana
    I finished my trans install last weekend. The trans is working great. I installed the TCI pan Part #890-378015. It has a magnetic drain plug, uses an o-ring instead of a traditional gasket to seal to trans body. It also comes with stainless steel mounting hardware. They claim 3.3 extra quart of fluid, but I think it is the same as the gm deep pan (I only needed 8qts of fluid when I got trans in). They must rate it over the shallow pan. Over all It is a very nice pan, not cheap, but no fitment issues at all. I'll give it a
    Looks good under there! That crossover pipe on the 4wd hangs low enough.
    Mar 2008
    filter part #?
    i just bought the same pan but im having trouble finding the correct filter that tci wants.
    please help
    thanks,
    kid
    Aug 2005
    Use the Same filter For the deep GM pan.
