Thread: turbo questions for custom build
    Jan 2007
    i have a couple of questions for a turbo custom build
    what turbo, size of plumbing ,wastegate, blow off val. should i look for
    what other things should i be thinking about trans, fuel, engine, gauges.
    any help or suggetions will be lots of help thanx people.
    never mind about the turbo stuff "but any thing else will help"
    2001 silverado 4x4 ext. cab, 2006 front end, cold air intake, msd spark wires, flow master, hp tuning, 20" bbs rims, 2" drop in back, e-fans
    http://i134.photobucket.com/albums/q.../jaxbigger.jpg
    Jan 2006
    <div class='quotetop'>QUOTE(jaxpewter2016 &#064; Jan 5 2007, 03&#58;09 PM) [snapback]78429[/snapback]</div>
    ALLEN NELSON, NELSON PERFORMANCE, CAN SET YOU UP.
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
    Jan 2007
    thanx for the help
    Ft. Worth, Tx
    for the motor at the least rod bolts if you plan to exceed 500hp. If you want to run alot of boost forged rods and pistons ( lower compression )
    Built tranny cause that wont last long.
    I would do pre fab hot parts to save time unless you dont mind the truck being down............trick/nelson, TRT/sts
    do a blow off valve to save the compressor, doesnt have to be the most expensive or best out there if you have an automatic but dont be cheap either.
    Alot of people run the GT67 turbos, it all depends on how much power you want to make.
    As far as the waste gate goes that depends on location, size of turbo, A/R. The mounting flanges are different so if you plan on going with a big turbo and high hp a larger waste gate might be good to start with.
    You will need to do fuel system upgrades at the least a 255lph in tank and 42# injectors, but that all depends on how far you want to go. You could go with dual in tanks and 60# or 75# injectors. If you plan on going with alot of boost I would switch out the intake for a carb style with an elbow to evenly distribute the air. Its not the cheapest thing around, but its cheaper than getting a new motor.
    Also get a boost controler either manual or electronic
    You can get more info by contacting Nelsonperformance, TrickPerformance, or TRTurbo..
    90 GMC RCSB Forged 370 and Built 4L80E from the VHO going in slowly but surely
    89 fox body notch... No motor or tranny mod but a narrowed 9" w/ 35 spline axles and a spool!!
    2011 Tundra CM 4x4...
