Thread: will it handle it
    ok gearheads i need some advice im planing on installing a 6.0 ls1 or maybe an ls2.plans go for full bolt ons and a silent drive supercharger.im thinking can the crank and rods hold on to that much power
    Jan 2006
    Yes they can up to a certain point. You will need to pin the crank.
    Jamest
    12 Sec. Club! SOLD
    SOLD***
    Jul 2006
    College Station, TX
    what is pinning the crank?
    2004 EXC Silverado 6.2L
    Mods:
    or should i stroke the engine
    Jun 2005
    Round Rock
    I think we should let SC answer the "Pin The Crank" question!!
    Just as it sounds, drill a hole between the crank and pulley to install a dowel that acts like the key on the old SB Chevys...
    08 HHR SS
    Jul 2006
    College Station, TX
    JAMEST just told me about what happened to SC. All i can say is ouch.
    Mods:
